Old 04-07-2008, 05:44 PM
homeboy homeboy is offline
homeboy is on a distinguished road
Default vibration,gas pedal
i noticed yesterday on the freeway from 60 to 75 mph anyone else had this problem?i leveled mine by cranking up torsion bars could that be causing front end wear?
Old 04-07-2008, 08:36 PM
Default Re: vibration,gas pedal
How many rotations did you crank up?
Old 04-07-2008, 09:58 PM
3 on drivers side just under 3.5 pass.
Old 04-08-2008, 03:00 AM
trailerpup's Avatar
My question is... what is the measurement from center of hub to fender lip?? I believe it should be no more than 24.25 inches max.
Old 04-08-2008, 03:40 AM
tomp's Avatar
tomp tomp is offline
Sounds like you raised it too much and are getting vibration from half shaft joints
Old 04-08-2008, 11:20 AM
mines at 24 inches it still has a slight rake to the front
Old 04-09-2008, 01:06 AM
trailerpup's Avatar
Maybe threw a wheel weight up front? As long as you had a quality alignment done you shouldn't be seeing any strange wear patters... except from the natural cupping that will occur with knobbys from turning.
