Old 04-21-2008, 06:14 PM
moorec614 moorec614 is offline
moorec614 is on a distinguished road
Default Tie-Rod / CV Replacement Procedure?
I'm going to pick up a spare tie-rod and CV, but I don't know how to replace them.
Does anyone have a write up?
Thanks.
Old 04-21-2008, 11:17 PM
Default Re: Tie-Rod / CV Replacement Procedure?
Tie-Rod
Remove nut at knuckle and remove TRE from knuckle. If it doesn't want to come out, hit the knuckle with a hammer next to the TRE. It's a tapered bolt so that will usually pop it out. Pull the boot back from the rack and remove the TRE from the rack. Put the boot and jamb nut on the new TRE. Adjust the length so it matches the one you took off. Put the new one on and reattach the boot to the rack.
Half-shaft
Haven't had to do one yet, but here's what I was told by one of the GM tech's.
Remove brake caliper (2x 15mm bolts). Remove spindle nut (35mm or 36mm). Remove nut from upper ball joint. At that point you should have enough play to tilt the knuckle outward and pull the axle free.
Old 04-21-2008, 11:25 PM
Thank you very much.
What's a TRE?
Old 04-21-2008, 11:39 PM
Desert Dan's Avatar
Tie Rod End?
Thanks for the description
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 04-22-2008, 05:54 AM
Originally Posted by Desert Dan
Tie Rod End?
Yep. I'm a lazy typist.
