Old 10-07-2005, 04:19 AM
Kracker Kracker is offline
Kracker is off the scale
Does anyone else have a problem with a loud vibrating sound at high speeds(75-80mph) coming from the light bar?
Old 10-07-2005, 11:03 AM
First Hummer is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Kracker:
Does anyone else have a problem with a loud vibrating sound at high speeds(75-80mph) coming from the light bar? </div></BLOCKQUOTE>
The marker lights have been an issue from day one.They supposedly have a fix coming out.Take them back to your dealer and complain.
Old 10-11-2005, 12:41 PM
J from the D J from the D is offline
J from the D is off the scale
Mr Kracker, your issue is definitely a valid one. Marker lamps are now on quarantine due to the wind noise you speak of.
GM says there is a fix coming.
As far as when... that's a good question.
Old 10-12-2005, 01:04 AM
Thanks for the replies. Man, is it annoying. I will probably attempt to fix it on my own like a few others have done.
Old 10-12-2005, 01:56 AM
BeerDog BeerDog is offline
BeerDog is off the scale
You should take them back to the dealer.. I've had mine for 3 months and haven't noticed any difference in wind noise.. Have them double check their installation...
BeerDog
Old 10-12-2005, 02:39 AM
can't wait for the dealer that long, so I fixed it myself...
see link:
http://elcova.com/groupee/forums/a/tpc/f/2706067735/m/7...691070241#8691070241
Old 10-13-2005, 07:41 PM
erick vargas erick vargas is offline
erick vargas is off the scale
just put a strip of blue painters tape across the front for now and that will iliminate the noise completely, until the fix comes out. run the tape b/w the marker lights and the truck
Old 10-14-2005, 01:46 PM
Thanks for the replies. Man, is it annoying. I will probably attempt to fix it on my own like a few others have done. </div></BLOCKQUOTE>
Kracker, go to pep boys and pick up some door edge molding for $7.Place it on front of marker lights it should just slide rite into place ,there is a strip of glue inside that will hold it in place.Thats how I fixed mine.
