Old 05-05-2008, 10:55 PM
H2BRUTE H2BRUTE is offline
Location: GAIN INFORMATION AND EDUCATION RELATING TO HUMMER H2\'S
H2BRUTE is off the scale
Default Door handle/insert problem
Hey all you techies..After having the BRUTE airbrushed back in March, (they disassembled and removed all hardware) my drivers side door handle and insert has become detached on one side of the handle. My question is, can this be fixed? If so, got any suggestions on how to remove the inside door panel to get at the door handle...As always, your help has proved invaluable..Thanks again, BRUTE
Old 05-19-2008, 08:15 PM
Default Re: Door handle/insert problem
Well, I finally decided to take the BRUTE back to the dealers to fix the door problem. Come to find out after they took the door panel off, the bolt holding the one side of the handle in was sheared off. According to them it was overtightened. Fortunately they looked around in the shop and found a used one which they installed at a minimal cost to me...Problem solved..BRUTE
