05-07-2008, 03:41 AM
Question about part in Hummer ?
What this part for?
What is doo in the car?
05-07-2008, 04:53 AM
Re: Question about part in Hummer ?
The first pic shows the airbox canister, the others are the snorkel.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
05-07-2008, 03:19 PM
What is the snorkel ?
05-07-2008, 03:27 PM
It keeps water from going into the air intake. Don't take it off. You need that.
05-07-2008, 03:46 PM
Can you Explain more about it ?
with Photos
05-07-2008, 09:10 PM
with Photos
Nope. 2 question maximum per part.
Think about it a little. What happens to you when you get water in you, where only air should be? That's what that does.
29-Jul-2008
05-07-2008, 11:01 PM
you are really smart
how you come up with that
05-08-2008, 02:06 AM
with Photos
You're joking, right? It would be a picture of a Hummer that would not start.
05-08-2008, 08:50 AM
with Photos
I don't have pictures, but technically speaking you can run the truck without the air intake stack and the filter. Your engine wouldn't last very long, the filter canister keeps sand, dirt and dust out of the engine intake and turbocharger.
The air filter can is huge, like a big truck or construction vehicle because the H1 is designed to work in dusty/dirty environments. That's why the air filter is two to three times the size of most other trucks/suv's air systems.
The intake mushroom/snorkel is less critical. It acts as sort of a prefilter to keep the big stuff, like snow/mud/dirt from getting into the filter system. The snorkel isn't super useful for water fording, because there is a duckbill/dust trip on the bottom of the air filter can. [military humvee's have a sealed can and a lever to seal the venting system for the driveline] If you sit in deep water for too long, water will get in through the air filter and you'll hydrolock your engine. If you bend a connecting rod or crack the block you're looking at a rebuild or replacement.
The gasoline H1's have 2, one on each side which is kinda odd, I did a double take when I checked under the hood of a gas h1.
Kurt Williams
1998 H1 HMCO Model 90 6.5L Turbo Diesel
05-08-2008, 10:51 AM
Thank you for the explain
