05-08-2008, 04:00 AM
Squeaky Brakes
I own a 06 sut and my brakes are driving me crazy! They squeak every time I push the brake. Pads are good. I have had the rotors turned and it stopped for a while. Any suggestions for a fix? Thanks, M
05-08-2008, 04:03 AM
Re: Squeaky Brakes
Turn your radio up...that's what my service advisor told me!
2008 Black H2
05-08-2008, 04:06 AM
Re: Squeaky Brakes
You did not mention the milage or if you do a lot of towing.
We had our pads replaced and the rotors turned at 65000.
We also upgraded to ceramic pads that really help a lot.
~Richard
05-08-2008, 04:08 AM
Re: Squeaky Brakes
Chamfer the edges of the pads. Thats what causes brake squeel.
05-08-2008, 04:16 AM
Re: Squeaky Brakes
45k miles. Not much towing. Thanks
05-08-2008, 04:17 AM
Re: Squeaky Brakes
[quote=H2Blondie]Turn your radio up...that's what my service advisor told me
05-08-2008, 04:49 AM
Re: Squeaky Brakes
One of the most causes is after they turn the rotors the mechanic need to reclean the surface areas and keep his greasy fingers off those areas of the rotors and Pads. any little grease or oils will make the brakes squeal and inferior pads can give you grief as well.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
05-08-2008, 05:55 AM
Re: Squeaky Brakes
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
05-08-2008, 06:03 AM
Re: Squeaky Brakes
Originally Posted by Rico001
Please take your Hummer to another service center H2 Blondie or
either don't follow too close.LOL
~Richard
Don't worry; that was on the '05 I traded back in December. Someone else gets to listen to it now.
2008 Black H2
05-08-2008, 12:23 PM
Re: Squeaky Brakes
Here's a real easy fix that works 99% of the time.
Take your truck out on an empty road, get it up to about 60, and hit the brakes as hard as you can. The squel is caused by a buildup of brake dust on the pads. This action breaks it up.
Try it, bet it works !!!!!!!!!!
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
05-09-2008, 12:46 PM
Re: Squeaky Brakes
The H2 along with my Z06 have this same issue...... after 50 miles my wheels would be nearly black, when I put the CCW wheels (polished alum) on my Z06 I added ceramic pads along with cross drilled rotors.... No more squeaks or dust.
On the H2 I have not added ceramic pads as the dust/squeal issue is not nearly as bad, every other time I wash it I take it to one of the high powered spray pressure washes (do it yourself place) and clean the wheels/rotors/pads really good..... this eliminates any squeal that I had.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
05-10-2008, 06:11 AM
Re: Squeaky Brakes
I have 114,xxx miles with the factory brakes and pad remaining. I have not experienced any squeaking.
05-10-2008, 07:17 PM
Re: Squeaky Brakes
put it in reverse get going slow and hold down the brakes and give it gas at the same time and go a about 200 feet. It reverses the glaze a bit and almost always takes the squeak away.
05-14-2008, 09:38 PM
Re: Squeaky Brakes
You need to use the red caliper grease on the back of the calipers.
1994 Chev Suburban Blown
05-17-2008, 01:28 AM
Re: Squeaky Brakes
IF you have heat glazed the rotors and pads already you will be liveing with that squeeking for ever. new rotors and the propper GM spec pads and a good cleaning and lubeing of the calipers is the answer . every time you cut the rotors you make them thinner and more prone to over heating and warping . rotors will take 1 cutting and still be good at disapateing heat after that the secound cutting will work but they will be too thin to properly dissapate heat . you could get a couple of cans of brakekleen and some caliper grease and clean them and see what happens ,it cheap enough . and it may help if it's just a build up of brake dust .
A government big enough to
you have.
-- Thomas Jefferson
07-26-2012, 07:48 PM
Re: Squeaky Brakes
HERE'S AN OLD THREAD!
I had new GM pads and rotors put on about 8-9,000 miles ago. They've squeaked since day 1. At first I thought...'Give it some time...they're just learning to play nice.' But it's been 8-9,000 miles...(sigh)...and still the same annoying squeak.
The only nuance that I've noticed with mine is that they only squeak at very low speeds...under 5-10 mph, like when creeping to a stop at a light. The squeak is ear piercing and only appears to occur on part of the rotation...sqeeeeeaaaaak...no squeak...squeeeeeaaak...no squeak...stop. I don't know if that really means anything or not.
I was in for an oil change and tire rotation last week and asked the tech to take a look. All they told me was, "the brakes and rotors look fine." LOL...I don't care how they 'look' I care how they 'sound.' They were really slammed that day so I figured I'd have them give it another look-see when I go in for my tranny flush next month.
I'm tempted to act on some of the feedback in this thread but thought I'd resurrect it first to get some other's input.
EDIT: I never had a single squeak that I remember with the original brakes and rotors... the ones that were on the truck when new.
CNTRY
DTOM
07-29-2012, 03:08 PM
Re: Squeaky Brakes
I had a problem with very noisy brakes about a mon ago. Had new EBC yellow stuff pads on slotted EBC rotors. The squeaks were so bad that I completely ripped apart the whole front brakes and lubed everything.
Back of pads
Caliper bolts
I also removed the bracket and painted both it and the caliper.
When I put it all back to get her, also bled the system to flush all the old fluid out.
Honestly haven't heard a single squeak since then.
Granted, I know it was from the lube on the bolts and pads, but peace of mind knowing there is fresh fluid in it too.
07-29-2012, 06:13 PM
Re: Squeaky Brakes
My old man had an H3 long before I picked up my 2 and he complained of the same issues. I did the same thing, broke the calipers down and greased EVERYTHING. Also be sure to grease the back of the brake pads-most have metal shims attached and even those can cause noise. Grease everything and it will go away!
09-18-2012, 05:47 PM
Re: Squeaky Brakes
Use Brake Quiet glue on the back of the pads, not grease. The brake quiet is a rubber adhesive that keeps the pads from vibrating when you lightly press the brakes. It should solve the problem when you lightly touch the brakes when going slow.
To the guy who has 114000 miles on stock pads/rotors.....WOW.
