Old 05-21-2008, 05:14 AM
milbrath47 milbrath47 is offline
milbrath47 is on a distinguished road
Default Transfer case oil change question
Hey guys!
I am doing the 50,000 mile service on my H3 and I am trying to figure out how to change the transfer case oil . My question is how are you guys getting the oil into the transfer case after draining it? Are you using a siphon or manual pump of some sort? This is no job for a funnel from what I can see........Any other recommendations for the fifty thousand mile service..... I already changed out the air filter, and I heard it is also a good time to change the transfer case oil in the front and rear axles..... I am planning on holding off on that because I have yet to engage in any hardcore off roading.
P.S I already know about the extra fill through the speed sensor
Old 05-21-2008, 05:54 PM
Default Re: Transfer case oil change question
Figured it out! You can either use a turkey baster or a small siphon pump from autozone for oil and fluid transfer.. Any other recommendations for 50,000 mile service will be greatly appreciated.
Old 05-21-2008, 09:03 PM
H3slate's Avatar
H3slate H3slate is offline
You got it! Use a hand pump, there is not a lot of room to manuever a turkey baster at the right angle to fill it.
Old 05-22-2008, 03:26 AM
Ryan Graham Ryan Graham is offline
Ryan Graham is on a distinguished road
You need a fluid transfer pump of some type. I just did mine (at 19K) and it came out pretty dark. I used synthetic fluid and am probably going to increase that interval to every 10K to make sure it lives to a ripe old age. I also did the diff's. The front was pretty clear and the back wasn't to dark but obviously had some wear particles in it. I would recommend doing your diffs now. They're pretty easy (drain plugs and fill plugs) and take about 5 quarts of synthetic fluid.
