Old 06-08-2008, 02:34 AM
sampson sampson is offline
sampson is on a distinguished road
Default Dash problems
I have a 2004 H2 and am trying to get the navigation stero out and I can't get the dash piece off it seems to be caught down on the bottom where the shifter is but I can't seem to see what is holding it in. Does anyone know what I need to do to get the cover off so I can get to the stereo? Thanks
Old 06-08-2008, 04:21 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Default Re: Dash problems
Yes there's two Phillips screws at the bottom of that cover. They're hidden behind the shifter/cup holder cover assembly. The tranny shifter handle needs to be removed first. To do that you need to back out the torx set screw (don't totally remove it), and lift up and pull the shift handle off. After that the cover plate can be pried up and off, it's held in place with clips.
BTW, the factory service manual says the whole center console needs to be removed, but I was able to accomplish this without doing that.
Old 06-09-2008, 12:18 AM
thanks
Old 06-09-2008, 06:37 AM
LV_H2 LV_H2 is offline
LV_H2 is on a distinguished road
Try this link:
http://www.elcovaforums.com/forums/s...ht=remove+dash
LAS VEGAS H2
2007 Victory Red LE H2
2005 Yellow H2 - Traded
2004 Victory Red LE H2 - Traded
Old 06-09-2008, 01:48 PM
s_c5519's Avatar
s_c5519 s_c5519 is offline
s_c5519 is on a distinguished road
well this post if from 3 days ago so I am guessing you got it out by now but for future doers....
yes, as Summitup says, remove those 2 screws and then it's pretty wedged in there, you just have to have to pull it out, it's a bit scary at first, but stuff a cloth or something in the bottom so you wont scratch it and keep a yanking...
