Old 07-16-2008, 11:49 PM
cmd's Avatar
cmd cmd is offline
cmd is on a distinguished road
Default Front Diff mount bushing assy
I removed my front crossmember with the rear diff mount and noticed with the diff hanging on the front mount that there was a lot of play, should there be a significant amount of play at the front mount?
Old 08-08-2008, 01:39 AM
dochummer's Avatar
Default Re: Front Diff mount bushing assy
When I removed mine I noticed that there was some play. There are two other bolts holding it up, so I wouldn't worry too much about it - unless those bolts are really loose.... Just my 2 cents..
'03 H2
Old 08-08-2008, 02:00 AM
Yetti Yetti is offline
I think you will find if the bushing sleeve was tight then the bushing will loosen with time. the flip side is if the sleeve in the bushing is loose then it will groan and make noise. make sure the bolts to the frame are tight to spec. as for the flat mount on the right side its serviced with both bushings installed. so if its that, just replace as needed.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
