Old 07-30-2008, 11:05 PM
Minuteman1636 Minuteman1636 is offline
Minuteman1636 is on a distinguished road
Default Question/concern regarding sunroof in the rain.
I drove my 2008 H3 in the rain for the first time today. I noticed that in the back corner (driverside) of the sunroof, there was a few drops of water coming through the seal.
However, there seems to be sometype of spring loaded tray, just below the spot where the drops were coming through, that was catching the drops.
So, based on my observation, I have a few questions:
1. Do I need to be concerned about the few drops coming through?
2. Is the purpose of the spring loaded "tray" to divert away any water that comes through that portion of the sunroof?
3. Where does the water go if it is purposely ending up on the spring loaded "tray"?
Thanks for your time.
Old 07-31-2008, 12:13 AM
Default Re: Question/concern regarding sunroof in the rain.
your sunroof should not leak!!! ...sounds like your's is.
Old 07-31-2008, 12:35 AM
NO !
Last time I checked the booklet said "IT LETS THE SUN THROUGH ONLY"
Old 07-31-2008, 12:57 AM
Bully13's Avatar
Bully13 Bully13 is offline
Yup.. took mine through a car wash last week and the sunroof leaked. And then I drove away and the plastic panel on the hood came undone and was flapping in the wind like a front spoiler. Hummer of Sac has been good to us though and was all taken care of through warrantee.
Old 07-31-2008, 04:11 PM
H3slate's Avatar
H3slate H3slate is offline
Obviously your sunroof should not leak. On a sunny day open your sunroof and look at the two front corners. There is a drain on each side, which can get clogged by debris, like pine needles. Make sure these are unclogged, any water that gets past the sunroof should go through these drains. Also make sure your sunroof is closed all the way. If you still have a problem with leaks, take it to the dealer.
I have had water coming into the cabin from the sunroof a couple of times. The fix was to unclog the sunroof drains.
Old 07-31-2008, 05:57 PM
6pack 6pack is offline
6pack is an unknown quantity at this point
I haven't had a problem with leaking, that I've noticed. I've wondered what the springy thing was for also. Maybe it works as a wind diversion so air doesn't poor straight onto you while driving?
2007 H3 Lux/Adv 5 speed, Gibson Extreme Duals cat-back, K&N FIPK, PCMforless tune, SAW torsion bars, Samco Shackles, Fox Racing shocks, Trail Duty Bump Stops, 35" ProComp Xterrain tires w/Tactical Rims, Gobi Stealth Rack
Old 07-31-2008, 10:22 PM
blindzebra's Avatar
first question. was it shut all the way?
Old 08-01-2008, 02:29 AM
It was shut all the way. I triple checked. I got this reply on another hummer forum. And, based on my observations, this makes sense. My tray was not overflowing.
"I have an 06 with the sunroof. The sunroof is not sealed to keep out water. The tray is supposed to catch the water, you need to worry when it starts to overflow.
There is a drain in each corner to drain the water. The two front ones go down the A-pillars and drain just behind the front tires. I think the back ones go down the B-pillars.
I occasionaly wipe any accumulated dirt out of the tray to help keep the tubes from clogging. If it's been awhile since it rained last, probubly wouldn't hurt to run some water down the tubes to help clean them out. Also if you lube the tracks yourself watch the overspray. Lubricant with any dirt will clog the tubes in no time.
I've read Hummer wants $600 to clean any clogged tubes. "
Old 08-08-2008, 06:07 PM
Lex_Ordo
My '06 leaked a few drops too, when I first got it. I brought it back to the dealer and they put a new seal around the glass. Seemed to have cleared it up. Now there is also a tray that the glass track sits in that is under the headliner. It diverts any water that does leak in, to the 'A' and 'B' pillars as a gutter/leader system to drain.
Old 08-09-2008, 03:26 AM
Dave92270's Avatar
my sunroof leaks a bit in the carwash - I have no means to figure out if it leaks in regular rain, because it hardly ever rains here, so I don't care. I'd get the sunroof again, despite somewhat queationable seal quality. It's just a few drops, who cares - but our other vehicles roofs are 100% water seal. H3 is special I guess, well no problem at the end.
Old 11-28-2008, 08:04 AM
Nw2HumWrld's Avatar
Nw2HumWrld Nw2HumWrld is offline
Nw2HumWrld is on a distinguished road
I had bought my H3 06 used. I have intermitent problems like that. Except my water is coming through the deiling on the left and right B posts. It literally leaks like a funnel. I havent had water leak around the sunroof yet though.
Old 12-01-2008, 09:10 AM
HBH3 HBH3 is offline
HBH3 is on a distinguished road
I just had mine at the dealer last Wednesday because it was leaking like mad with the rains in So Cal. Turns out the dam tree I park under every day dropped so much debris that made its way into the infamous drainage holes. They had to unclog the holes and remove headliner to dry out all the water. Tustin Hummer was nice enough to do it the same day so myselft and my family could go on our Thanksgiving getaway to Mammoth Mountain.
