Old 08-15-2008, 05:54 PM
brad_p's Avatar
brad_p brad_p is offline
Default Aux input
Ok i want to hook my sirius up direct instead of the fm transmitter thing. I have the 6 disk changer in an 06 i undo the radio and all that to find no aux hole in the back. There is a Aux button but no hole im confused, did i overlook it? If there isnt one how did you guys get your aux plugs put in?
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 08-15-2008, 07:11 PM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Default Re: Aux input
I'm not sure this is correct, as I only have Nav. But, don't you use the Cd Changer as an alternative conection. Or is there not an AUX on the back of the changer...
Old 08-15-2008, 08:00 PM
brad_p's Avatar
the button says cd with aux under it.
----------o-o-o-o-
[[_]|[]|[][___]
Old 08-16-2008, 12:29 AM
Rico001's Avatar
Rico001 Rico001 is offline
Brad you will need a GM12-AUXV2 and a Monster Cable w/ RCA to 1/8 Stereo cable.
I have this same hook up and it is on my things to do list this weekend.
I got mine from Crutchfield and it also came with the directions on how to remove the center dash and console unit.
PM if you need help or any more info.
~Richard
