08-22-2008, 06:24 AM
Scolded Dog!
My H2 has about 18,000 miles on her, so I decided to take the air tube off and clean the air intake. I sprayed some carburator cleaner around the intake, and then pushed the intake open with one finger and then sprayed a little into the intake. I then took a paper towel and carefully wiped all the cleaner up, including cleaning the black stuff out of the intake. Replaced the air tube and fired her up. She now runs like a scolded dog!
I once had an Avalanche that was running rough and a mechanic told me that if you did this on your vehicle at about every 15,000 miles, it would make a heck of a difference. It did, and now I do it to my vehicles about every 15,000 miles.
I'm sure that someone can explain it better than I did, but you get the idea.
08-22-2008, 06:42 AM
Re: Scolded Dog!
Thanks for the info...
08-22-2008, 05:58 PM
Re: Scolded Dog!
Isn't the T/B plate coated with a non-stick styled material that should not be carb cleaned?
Want-08 Viper, 06 M5
08-22-2008, 07:30 PM
Re: Scolded Dog!
You dont have a carb.. You should have used intake cleaner for fuel injected vehicles, they are formulated differently for the "sensitive" electronics that are on a fuel injected vehicle. Try letting it idle for about a half hour, if the problem persists, or the check engine light comes on, its gonna need to go to a dealership... Good luck
_____________________________________________
2003 H2 w/ adventure package,4" Rancho lift, 20" cruiser alloys, Blacked out, 7" In dash DVD, Wood Kit, Billet chrome handles
08-23-2008, 01:50 AM
Re: Scolded Dog!
In this case "runs like a scolded dog!" means it runs great
08-23-2008, 01:51 AM
Re: Scolded Dog!
Yeah I was just re-reading it, glad its running good! But be careful about the carb cleaner, those sensors can get quite pricey!
