Old 12-22-2005, 09:52 AM
JetEyeNite JetEyeNite is offline
JetEyeNite is off the scale
Hello all.
Does your LCD monitor show what you see on your rear-view mirror? The reason why I am asking is that maybe the camera you have was not specifically designed to be used as a backup camera. Look at the LCD and see if your left and right is reversed. What is on your rear-right maybe showing on the left side of the monitor and what is on your rear-left maybe showing on the right side of the monitor. I know if you turn your head around to look at the back of the car, what you then see is what you are seeing on the LCD if the camera/LCD setup is a simple camera setup.
I just saw another thread (http://elcova.com/groupee/forums/a/t...1/m/6741072051) w/ different backup camera and it has a switch on the LCD to "fix" this.
Could you please post camera manufacture name and L/R reversed or not?
ie) cheap ebay cam -> L/R reversed
ie2) v3 cam -> L/R corrected.
thanks all in advance and happy holidays...
04 Pewter Lux
