Old 09-12-2008, 01:19 AM
kris01 kris01 is offline
kris01 is on a distinguished road
Default Power door lock problemo
Having problems with my locks all of a sudden...doors will not lock by clifford remote..worked fine since 2003...since yesterday they'll unlock but wont lock....they work fine if I manually lock them from inside driver's side door....a fuse or relay problem?...any help would be appreciated
Old 09-24-2008, 05:06 AM
bonzaiii bonzaiii is offline
bonzaiii is on a distinguished road
Default Re: Power door lock problemo
I'm having the exact same problem. Any solution yet on your end ?
Old 09-24-2008, 05:35 AM
lasvegash2's Avatar
lasvegash2 lasvegash2 is offline
lasvegash2 is on a distinguished road
i had the same problem with mine also but it was more intermitten...i had to check my door before i walked away to make sure it locked...pita....i do have a clifford sst remote for sale if its the same kind...i have listed under the classified... http://www.elcovaforums.com/forums/s...ad.php?t=35436 i dont know if its the same one you have but it works up to a mile.
scott j.
2008 h2 sut
2008 escalade
1969 charger
Old 09-26-2008, 07:57 AM
H2Finally's Avatar
Mine's the stock H2 autolock -- but the few times it wouldn't lock, turns out simply that the back hatch wasn't shut properly / something caught in the jam.
Can BLING Get You Home?
Old 09-27-2008, 01:43 AM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
Had same problem couple months back. Turned out my remote was bad. They programmed a new one for me and no problems since. A Clifford dealer installer should be able to check this for you. Good luck.
