09-16-2008, 03:04 PM
SUNROOF WONT SHUT??????
Any info would be great?it starts to shut then reverses it self??
09-16-2008, 05:00 PM
Re: SUNROOF WONT SHUT??????
lots of posts if you search.
mine was bad for a while, had to help it close by hand. when it got very bad, the dealer replaced the "module"( i think its the entire tray that holds the sunroof) under GMPP. Would have been about $500 or 1k I think.
Now I onmly open it after I brush off the twigs, and I no longer crush my kids superheroes in it when they fight.
After the squealer repaired it, they left one drain hose disconnected, and it leaked over to the A pillar. That took a while to figure out.
09-16-2008, 05:38 PM
I had a similar problem on my H3 and it turned outto be a loose ground wire. A dealer fix under warranty
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
09-18-2008, 04:50 AM
I heard one guy that had to tight a fit because for some reason I want to think it has a pressure open switch like garage doors.
TAZ
09-18-2008, 12:55 PM
Mine wouldn't close 'cause of lack of grease. I don't use it alot, so it got all dry, and wouldn't close anymore. Had it greased up and now I have no more problems.
09-18-2008, 02:06 PM
did you just grease the rails?
