Old 10-14-2008, 06:16 PM
familyguy familyguy is offline
familyguy is on a distinguished road
Default Changing Geared Hub fluid
Has any tried changing the geared hub oil WITHOUT removing the tires? If so, any advice you can share on removing the drain plug and catching the draining fluid in the restricted space between the bottom of the geared hub and the inside of the wheel? Thanks!!
