Old 10-22-2008, 05:24 AM
Stellar Stellar is offline
Stellar is off the scale
Default Tire / Lift combo...Will it work??
Looking to run 35x14.50R17 Irok Radials on my tank...I have the Cognito front leveling kit and 1.5" coil spacers in the rear. Will these tires create any rubbing issues if installed on the stock wheels? Thanks in advance.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
Old 10-22-2008, 06:29 AM
Default Re: Tire / Lift combo...Will it work??
Don't think they'll rub
Old 10-27-2008, 07:15 PM
DuckTruck DuckTruck is offline
DuckTruck is on a distinguished road
They shouldn't be an issue re: height wise.....I'm running 37"s on my stock wheels, with no lift, and have no problems at all.
However, as for width, you might rub b/c running that wide of a tire on the stock wheel may put you into the front steering stabilizer up front and the shocks/coils/airbags in the rear.
DUCK
2003 H2, Lux & Adv Packages, Cognito 3" front suspension lift, Gobi Stealth Rack w/ Ladder, Navigation, twin Optima battery setup, AirRaid Intake, Granatelli Mass Air Flow Sensor, Flowmaster Big Block II Exhaust, Diablosport Predator Programmer,Cognito Pitman/Idler Arm Kit, Fabtech Tie Rods, Rancho RS 9000 shocks, Warn bumper and 9.5x winch, Warn light bar, PIAA's everywhere (14), everything blacked out, and rollin' on 39.5" Super Swamper IROKs on black powdercoated stock wheels.
Old 11-01-2008, 02:10 AM
I appreciate the feedback. Anyone have any experience running wider tires?? I have coils in the rear, it seems as though there will be enough clearance. I'd like to hold off using wheel spacers if possible. Thanks in advance..
2005 Black LUX
37x13.50R17 Toyo MT
2" wheel spacers
Bilstein stabilizer
