Old 05-02-2005, 07:57 PM
jose jose is offline
jose is off the scale
i´m from spain. i´ve bought a h2 in miami two months ago. now the speedometer starts sometimes at 60 mph , other times at 40mph....
i tried to disconnect the battery for some minutes and connect again and for a few moments it works ok, but after some miles it makes the same thing....
what can i do?
tks and regards to all
what can i do?
Old 05-03-2005, 09:13 AM
partsguy partsguy is offline
Rebuilt cluster,In the states around 225.00
in Spain ?????????
Old 05-12-2005, 09:10 PM
my english is not so good..but cluster means the piece where is speedometer, tachometer, oil, temperature.....?????
here in spain hummer service has no idea of hummers....
can i repair it myself?
regards
Old 05-12-2005, 10:54 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by jose:
my english is not so good..but cluster means the piece where is speedometer, tachometer, oil, temperature.....?????<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> <span class="ev_code_RED">Yes,It all housed in one unit.</span> </div></BLOCKQUOTE>
can i repair it myself?<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> <span class="ev_code_RED">Do you have a outlet for the cluster,Maybe the united Kingdom?I can help you with the installation of the cluster.I</span> </div></BLOCKQUOTE>
regards </div></BLOCKQUOTE>
Old 05-12-2005, 11:43 PM
tower's Avatar
tower tower is offline
Estimado Jose,
Usted es bastante correcto. El grupo es el aparato que alberga todos los calibradores. Partsguy dice que él le puede vender el grupo para $225, pero el envío pueden ser prohibitivamente costosos. Adicionalmente, él le puede ayudar con instrucciones de instalación, pero piensa que usted quizás haga para buscar bien un suministrador de partes de Hummer y a mecánico en Gran Bretaña.
Old 05-13-2005, 04:28 PM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
Try local GM dealer. Here in Finland local GM Chevrolet dealer will do such stuff...
Old 05-13-2005, 09:54 PM
Yess.I thought he tried them...
Any GM dealer can help you>>>>>good job!
Tower trans Please!
Old 05-14-2005, 07:41 AM
W1N's Avatar
W1N W1N is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by partsguy:
Tower trans Please! </div></BLOCKQUOTE>
Currently H2 is not generally legal as it is in Europe (in European Union). However, with different modifications some countries acctept it. Here in Finland we have to change the head lamps, wind shield and tail lamps. Also bunch of annoying documentation must be provided.
All this because GM has not allowed H2's to be officially to be imported to Europe (bacause of the EU declared modifications and tests that has to be done). There are Hummer dealers across Europe (unofficial) and they do provide all the warranties etc on their own expence. Thats why local GM dealer could be actually better provider of the service than local Hummer dealer. Since the Hummer dealer could be just sales organization.
This all is about to change (Thank God!)
http://www.autointell-news.com/News-...r-16-05-p3.htm
