Old 11-11-2008, 09:51 PM
Flesh Flesh is offline
Flesh is on a distinguished road
Default Stereo died...
Ok so I pull into the gas station to get some stuff and everythings working fine. Get back in the Hummer and when I turn it on the stereo doesnt come on. No power to it what so ever. So far ive just checked the fuses and didnt find anything there. Is there anywhere else I should look before I go checking/replacing the amp or the head unit?
I didnt really wanna have to do stereo upgrades before I did other stuff to her first.
Old 11-12-2008, 01:30 AM
working Hummer's Avatar
Default Re: Stereo died...
What year? if it's an 03 I know!
Old 11-12-2008, 02:56 AM
Its an 04. The door chimes aren't working either. I'm not too sure if the amp supplies the power for all that stuff, or the head unit itself?
Old 11-12-2008, 03:47 AM
splne1's Avatar
splne1 splne1 is offline
did ya check the relay fuses under the hood!!!
Old 11-12-2008, 04:34 AM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
there are two fuse locations, one is under the hood and the other is behind the panel located to the left of the driver side air vent. there is also a little fuse puller and spare fuses on the back of the panel. Also is the stereo stuff stock or is it aftermarket parts you have put in?
B
Old 11-12-2008, 05:24 AM
The stereo systems just the stock 6 disc unit. I checked the fuses in both locations and everything checked out. There isnt any actual relays is there?
