Old 08-29-2005, 01:46 PM
After the H3 has been sitting a while (more than a few hours), does your engine sound noisy (like a roar from a fan) when you first start it and drive the first 100 feet.
Old 08-29-2005, 02:49 PM
Marc H3 Marc H3 is offline
Marc H3 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ChevyHighPerformance:
After the H3 has been sitting a while (more than a few hours), does your engine sound noisy (like a roar from a fan) when you first start it and drive the first 100 feet. </div></BLOCKQUOTE><span class="ev_code_blue">I had a squeal or whine noise at cold start ups. You might have the same condition that I had where some coolant had accidentally dripped onto the fan belt. Take a look at it to see if you can see any fraying that might be caused by a bent or misaligned pulley too.
Take to your dealer and ask them to check out TBS for noises in your engine. After my belt was changed she was back to her old self.</span>
Old 08-29-2005, 03:16 PM
wannabeH3's Avatar
i know exactly what your talking about.. your engine sounds really beefy right? its normal warm up sound
(with insurance)
Old 08-29-2005, 05:31 PM
wannabeH3,
It's a beefy sound. It sounds like you're revving the engine faster than you really are. What is happening to make this sound?
Old 08-29-2005, 05:42 PM
VTSTOMPER is off the scale
Fan!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 08-29-2005, 06:32 PM
Is it the fan clutch engaging fully for a short while causing the fan to go in synch with the engine (when it normally will be running at some slip speed). I know other GM trucks do this too (Avalanche, etc.).
Old 08-29-2005, 11:41 PM
hyperion78 hyperion78 is offline
hyperion78 is off the scale
I love that sound! Sounds like you're going to take off or something.
Old 08-30-2005, 08:57 PM
I never noticed; however, could it be the electronic throttle being opened by the PCM to get the engine running smooth after startup?
Old 08-30-2005, 10:07 PM
When you're moving while it's making this sound the engine RPMs stay the same as you hear the roar and then the roar fades away (while the RPMs haven't changed).
