Old 11-21-2008, 04:19 AM
Dave92270's Avatar
Default battery problem, AC Delco
Hi guys,
it seems that my battery suddenly died on me (in 2 days without any warning) - yesterday I noticed somewhat weak start but it started, and apparently recharged after short drive enough for repeat start on the way back from the store. Tonight I tried to start, and this time no chance, just buzzing... I checked out the battery, it is the original AC Delco that is supposed to be maintenance free? (no distilled water needed according to page 345 in the manual?). My vehicle was built late '06, is this common problem? I never had dead battery in 2 years in any vehicle I owned... maybe it is something else electrical possibly? Oh, my Onstar reports 100% everything perfect, haha.
I'll jump start (hopefully) the truck tomorrow and take it to the dealership to have a look - is the battery under warranty BTW?
Any thoughts? Thanks!
Old 11-21-2008, 12:08 PM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
Default Re: battery problem, AC Delco
The best thing to do is buy a Optima Yellow Top Deep Cycle Starting battery. I have a 08 Alpha and went through 2 factory batteries in the first 2 months!
2008 H3 Alpha - Boulder Gray
Old 11-21-2008, 12:28 PM
The stock battery is undersized. Get a decent battery and replace it...
The Plastic housing and base is also too small. Throw it out. However the metal tray and strap with it are good for any size replacement. Use a 8mm ratchet to remove hold down bolt on strap. Get a maintenance free type since the hold down strap is wide. Strap will cover caps on standard battery.
Good Luck!
Old 11-21-2008, 01:57 PM
my battery went at 35000 miles ...they replaced it for free, no pro-rating...
much cheaper then an Optima...!
and they gave me a free loaner for the day while they anal-ized the problem !!!
Old 11-21-2008, 07:00 PM
Dave92270's Avatar
Thanks for info; I guess that I'll take the vehicle to dealership and try to get a new free battery. If they'll replace it with the same one, I'll probably buy a better battery some day soon - to make sure this wouldn't happen again. Well, at least now I really believe it's nothing else electrical, just most likely a crappy battery....
Old 11-23-2008, 12:02 AM
Dave92270's Avatar
OK, so it turned out a bad battery - I took the truck to dealership today, they tested it "with Midtronics" and battery "failed with bad cell". New battery runs fine, all free of $$ charge... I'll have to lok which battery they installed, probably same model, according to service slip/workorder it is P/N 86-7YR, so another ACDelco.. I guess I'll eventually go ahead and buy Optima...
Why our sweet trucks come out of the factory with such a POS battery is a mystery to me.
Old 11-23-2008, 05:28 AM
Vandakeg Vandakeg is offline
Vandakeg is off the scale
Is a weak battery the reason for my headlights to dim when raising and lowering the windows?
Old 11-24-2008, 03:25 AM
Crash ?'s Avatar
Crash ? Crash ? is offline
Shoot there ain't a part on any non-exotic car out there that didn't come from the lowest bidder..
Rob
