Old 11-22-2008, 07:34 PM
working Hummer's Avatar
Default Door handles
Any one else have a problem with the outside door handles sticking pulled out a little so then you cant open the door from the inside when you close it? It's almost like the child lock is on but it isn't. I end up happening to get out and push the handle all the way in so the passengers can get out. If there is a problem seems it would be covered by warrany. OR it there an easy fix?
