Old 11-24-2008, 03:21 PM
HumminNBoatin''s Avatar
Default Help!! CEL is on Code P0174
Ok guys it was 18 Degrees on Friday Morning. I went out to start the H2 to let it warm up. I came back and saw the CEL on. I immediatly went to Advance Auto Parts to get the code pulled. and its
(P0174 system lean Bank 2) I had them reset it and it came on again Saturday morning Very cold morning as well. I had it reset again but it came on again not more than 15 minutes down the road so I know its not a cold start fluke.
So I did some research and looks to be an O2 Sensor. But not really sure witch one it is? I am thinking there are 4 O2 Sensors on the H2?? Anybody have a clue.
I am thinking that I will swap it with another one already on the truck maybe the opposite side and see if the CEL light will follow the problem to (Bank 1) first. If Thats the Case I am think I will try to clean it with some carb cleaner and see if that fixes the problem.
However if the CEL light comes on again and its the same (Bank 2) Does anybody know where I should start???
I am sure HumTech might have some ideas???
Thanks,
Eric
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 11-24-2008, 10:58 PM
05h2sut 05h2sut is offline
05h2sut is on a distinguished road
Default Re: Help!! CEL is on Code P0174
I don't know what year you have - here is the test for an '06
http://members.cox.net/dnb1958/P0174.pdf
Wouldn't imagine it would vary much.
Hope it helps
-Dave
Old 11-27-2008, 01:25 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
If an o2 sensor is the issue it will be the pre cat sensor on bank 2(right side) If it tends to set in colder weather mostly on cold starts you could also have an intake leak. The intake is a dry intake so if its leaking it allows unmetered air into that bank causing that bank to go lean. If you have access to a scan tool to monitor fuel trim levels, cold start the truck and force it into closed loop operation then spray air intake cleaner around the base of the intake runners, if the fuel trim goes lean your gaskets are leaking. Common on high mileage gen 4 engines. GM has since updated the gasket design to help eliminate future failures.
