Old 12-06-2008, 07:26 PM
nahanee20 nahanee20 is offline
nahanee20 is on a distinguished road
Default Burned CDs in a h2?
is there anyway to make them play in the h2. most of the time they skip, but does anyone know how to get them to work right?
Old 12-06-2008, 10:20 PM
HummerMann's Avatar
Default Re: Burned CDs in a h2?
I have an ENtronics DVD±RW Dual Layer burner and most of my burned CDs play fine in my H2. Just make sure your burner is capable of writing and re-writing DVD-RW DL and DVD+RW DL.
Hummer, like nothing else
Old 12-06-2008, 10:59 PM
jmsspratlin's Avatar
Never had any problems
Old 12-06-2008, 11:44 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
x2
-Brian
http://www.hummerguy.net
Old 12-06-2008, 11:56 PM
what type of disc are you using? and what size?
Old 12-07-2008, 02:39 AM
errett errett is offline
errett is on a distinguished road
Originally Posted by Hummer Guy
x2
x 3
I have used the cheapest from Disc Makers that were free with the purchase of a burner and I have used Memorex 700MB without issue. Mostly burning from iTunes in a Plextor PX-740A.
It may be your burner. The burner in my wife's laptop has issues and those discs skip in both our cars.
E
2006 Hummer H2 Adventure - Yep it's a hybrid! - SOLD
2006 Infiniti G35 Coupe - SOLD
2005 Honda Aquatrax R-12x - SOLD
2012 Dodge Challenger SRT8
2012 BMW X5 xDrive50i
Old 12-07-2008, 04:15 AM
E
concur
Old 12-07-2008, 10:03 AM
Some time ago, burnt cd's started skipping. My friend put a cleaning disc in the cd player and since then I had no more problems
Old 12-07-2008, 02:24 PM
porschett's Avatar
X4
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 12-07-2008, 02:57 PM
HummerJim's Avatar
X5
I've used the burner on my Gateway Computer and all the discs played without problem in the Hummer.
Old 12-07-2008, 04:59 PM
I'm gonna get a cleaning disc, but does anyone know if Cd-RW disc play better than Cd-R?
Old 12-07-2008, 06:08 PM
HummerMann's Avatar
I've used both with no problems. My biggest problem is being careful storing them. I normally just throw them in the console and they get scratched.
Old 12-07-2008, 06:24 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Cd-RW discs are rewritable/erasable and in my experience they do not perform as well as Cd-R, especially after many erase/rewrite cycles. They are also more expensive and it doesn't make sense to use them for music.
If your disks are skipping during playback, try burning them at a slower speed. Burning at 48X and higher will produce more errors, especially with poor quality media.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 12-07-2008, 06:27 PM
thanks for all the help, ill get a cleaning disc and burn at a lower speed.
Old 12-07-2008, 08:42 PM
I ended up burning mine at a slower speed and they work fine now. My 05' stock system never played a burned disk for 2 years until I asked this same question in off topic. Thanks to COHummer, I got it working in no time.
Old 12-09-2008, 12:39 AM
are you using a cd-r disc or cd-rw, and what brand and size is it. also does anyone know if using a cleaning disc is safe?
Old 12-09-2008, 05:03 AM
jaxtrip's Avatar
jaxtrip jaxtrip is offline
jaxtrip is on a distinguished road
I only seem to have problems when using CD-RW, they skip and sometimes just stop playing altogether.
Never had a problem with a CD-R. They burn faster too.
Old 12-09-2008, 09:34 PM
I think I'm using the CD-R Sony. See, I'm not much of a techno geek. I was having trouble getting a disk to play in my daughters Strawberry Shortcake CD player. When I tried it in the H2 it didn't work either. I had to burn the disk at 4x speed. When I found out that worked, I didn't try burning it at any faster speeds because it sounds fine to us.
When they weren't playing correctly, they sounded like they were scratched.
Old 12-09-2008, 10:16 PM
Gunzz's Avatar
Gunzz Gunzz is offline
Gunzz is off the scale
As said buring at slower speeds can make the disc work. I had this trouble a while ago and after burning at the slower speeds I never had a problem again.
Old 12-10-2008, 07:39 AM
I think using the cleaning disk from time to time (every couple of months) and writing them at low speed is the best deal
