Old 12-09-2008, 12:06 AM
zion1976 zion1976 is offline
zion1976 is on a distinguished road
Exclamation Fuel injector cleaner?Check engine light?!
Hey guys this is a wonderful forum! Anyway i just picked up a 06 H3 base with a 5 speed manual tranny and 32k miles..The car is in excellent condition and runs excellent..I recently filled the tank with 91 octane sunoco gas and than a day afetr i bought a bottle of Techron fuel injector cleaner.I know your supposed to wait till the tank is empty before adding the cleaner and than fill it up..So anyway i put the injector cleaner to a already full tank of gas.SO this afternoon i went outside to start my rig to warm her up a little.. i came back and there it was the dreaded check engine light..Car wasnt sluggish and ran excellent.. could this mishap with the feul injector cleaner caused this?? any thought would be appreciated..just hope it not the dreaded head problem!!!!
Old 12-09-2008, 07:19 AM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
Default Re: Fuel injector cleaner?Check engine light?!
Most commonly the gas cap wasn't secured tight enough. Make sure you have at least 3-4 turns that click when locking and run the vehicle for 3 to 4 cycles (Turn on, drive at least 5 miles, turn off). Then see what happens. If all goes well, your light will stop coming on.
Old 12-09-2008, 04:12 PM
fourfourto's Avatar
Anything higher then 87 octane is a waste,even pulling my 4,000 LB camper up hills I found higher octane not needed.
I put 20 to 35 gallon quality fuel injector cleaner (not the up to 20 gal stuff for cars)in at every oil change since new and have not had a problem.
I did add it then filled up? Maybe hook some turns and take off/stop hard try to stir it up a bit.
If you have onstar it will tell you the reason the light went on,Its still under warranty so bring it to the dealer if light stays on or comes on again.
Old 12-09-2008, 11:09 PM
thanks guys it just came off today..
Old 12-11-2008, 02:31 AM
Viet Nam Vette's Avatar
I remember reading in the manual GM "NOT recommending any Additives in the fuel including FI Cleaner... I could be Wrong BWTFDIK
Old 06-25-2009, 02:15 AM
zacknolden zacknolden is offline
zacknolden is on a distinguished road
I am having the same problem right now. What I want to know right now is, what exactly did you do for this one?
