Old 12-18-2008, 02:11 AM
Rockyot Rockyot is offline
Rockyot is off the scale
Default Engage Rear Locker in 4-Hi on H2?
has anyone come up with a switch or rewire so that i can engage the rear locker while in 4-Hi?
Today is the best day you are going to get. Enjoy it and lift somebody up with you.
Old 12-18-2008, 02:26 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Engage Rear Locker in 4-Hi on H2?
Can i ask why you would want to. Not a good idea cruisin down the road to be locked
Old 12-18-2008, 02:37 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
I also have to ask..... there is really no reason to engage the locker other than for crawling through the very rough stuff.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-18-2008, 06:10 PM
In the sand at Pismo Beach it would be nice to have the back end locked up. No need for 4-Lo. Locked works well in the snow too. Maybe it is just me??
Old 12-18-2008, 08:23 PM
HUMTECH's Avatar
Actually locked up is worse in the snow, tends to want to fishtail. My jeep is full time locked in the rear and tough to keep straight when in snow
Old 12-18-2008, 11:02 PM
Thanks for the heads up in the snow. In my Rubicon it was helpful in the sand in 4-Hi.
Old 12-19-2008, 01:09 AM
IRA51's Avatar
IRA51 IRA51 is offline
You haven't lived untill you went down a hill on pavement at 50 mph in the snow or ice with a locked diff .
A government big enough to
you have.
-- Thomas Jefferson
Old 12-19-2008, 03:57 AM
4hi locked (not locker) with the TC2 enganged is great in the sand!!!!!
Pismo? What are you airing down to?
Old 12-19-2008, 02:06 PM
MVR 155's Avatar
It will also cause the front end to shove badly at low speeds while turning.
2013 Audi S4
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-19-2008, 04:50 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
You got snow and ice in Phoenix!??
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 12-19-2008, 06:29 PM
IRA51's Avatar
Wink Re: Engage Rear Locker in 4-Hi on H2?
Just because I live in Phoenix doe's not mean I don't drive in snow country . I grew up and lived in northern New Jersey (Susex and Morris county ),and hunt in Northern Arizona and Colorado every year. I also spent 2 years in Bufalo New York . and have a set of chains for the H2,and my 05 Chevy 2500 HD ext cab 4x4 Duramax/allison pickup. I drive in the snow and ice every winter .
you have.
-- Thomas Jefferson
Old 12-19-2008, 06:31 PM
Desert Dan's Avatar
I know it is possible to bypass the low range lock out so you can use the locker in 4 high on Jeeps so it must be doable on Hummers too??
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 12-31-2008, 07:19 PM
DuckTruck DuckTruck is offline
DuckTruck is on a distinguished road
I asked this question a while back and got the same responses. My brother in law did it on his TRD tacoma.....it's called a "grey wire mod" on their forums....apparently you just have to fool the locker into thinking it is "grounded" all the time.
Can someone confirm that this has been done on an H2?
DUCK
2003 H2, Lux & Adv Packages, Cognito 3" front suspension lift, Gobi Stealth Rack w/ Ladder, Navigation, twin Optima battery setup, AirRaid Intake, Granatelli Mass Air Flow Sensor, Flowmaster Big Block II Exhaust, Diablosport Predator Programmer,Cognito Pitman/Idler Arm Kit, Fabtech Tie Rods, Rancho RS 9000 shocks, Warn bumper and 9.5x winch, Warn light bar, PIAA's everywhere (14), everything blacked out, and rollin' on 39.5" Super Swamper IROKs on black powdercoated stock wheels.
Old 01-01-2009, 07:33 AM
tomp's Avatar
tomp tomp is offline
Disconeect the rear locker connector and Add a 5 Ohm resistor in series with the two wires going to toward the front of vehicle. Next, add a new 12volt circuit with switch and relay to send power to the two wires going to the connector at the rear diff. It does not matter which is + or - as it is a coil and just needs 12volts to energize.
You are done and can now manually control the locker. The resistor is to prevent "Service 4WD" error as the system looks for this resistance to be present that would normally be the resistance of the locker coil.
Old 01-01-2009, 06:26 PM
Bronze's Avatar
Bronze Bronze is offline
Bronze is on a distinguished road
Most H1 and H2 Hummer have a feature where If you require additional traction without engaging the HI-Lock or Lo-Lock simply place your left foot on the brake then give slight power to the right gas peddle. It will transfer traction to the wheels that have traction and lock the wheel that is slipping.
Old 01-03-2009, 09:39 AM
HUMTECH's Avatar
Well thats half right, the H2 is equipped with open front and rear differentials with the eaton e-locker in the rear only. The H1 is equipped with torsen differentials front and back which allow power transfer with either driver input using the brakes or automatically if equipped with tt4, later models of the h1 were available with lockers front and rear as an option
