Old 12-30-2008, 11:24 PM
jroman201's Avatar
jroman201 jroman201 is offline
jroman201 is on a distinguished road
Default Body Frame Bolts
I have had my 04 H2 for nearly a year now...I brought it in for service earlier this year and posted up here...too lazy to look the post up now...but I brought it in again today for some of the same issues...a few of them I am concerned with...
I had a creaking/crackling sound coming from the front drivers side...sounded like a steering issue back then and they pretty much shrugged me off and told me it was normal and everything checked out ok...now since it would happen while turning more and more...i mentioned it again...the service dept told me today that it was the "body frame bolts" and they are not covered under extended GMP warranty...$135 to repair this...has anyone ever had this issue covered by warranty before?
I also have the infamous water leak that plagues the front marker lights on our trucks...I told them about it last year and they said no issues were found...but now they ran in under the shower and I need to pay $180 for a "re-seal" of the lights...and if that doesn't work...it is $170 per marker light for replacement...covered...not covered..???
I also experienced the wind issues at high speeds with the A Pillar exterior trim...they quoted me $90 for a "re-seal" of those as well...covered...not covered...??
and $33 for a rear wiper...gimme a break...I cant find it anywhere around Jax though...did not check online yet...
Now I know that some of these are a quick fix by myself...but they kept bugging me to bring it in...and now I want them to get it done...
A few good things will come out of this experience though...
I will be getting the upgraded mirrors under warranty due to the passenger side not retracting and the drivers side being loose....
I will also be getting a new rear drivers side window motor under warranty as well...
The truck was also having some issues with idling and sputtering at varying speeds...dealer tells me that this is the "knock sensors" and they will be replaced and covered under warranty as well...
GMP Warranty deductable is $50...
Thanks for all the replies...
Jacksonville, FL
