Old 01-15-2009, 07:22 AM
Default Who here has a lifted H3?
Anyone?
What did you do with your leaf springs.....?
Old 01-16-2009, 01:14 AM
Default Re: Who here has a lifted H3?
Hey Bebe long time no see
Did the 1" lift in the back using shackles with the turn up in the front on the bars.
Left the leafs alone. You might try the Colorado/Canyon forum. Those cowboys are always doing things to their rigs
Good luck.
Old 01-16-2009, 02:09 AM
Good luck.
Good idea!
My main leafs are all twisted up....again. (It will be my third set of springs )
I was looking for a set to do a spring over conversion...the CC guys might be the ticket!
Need to figure out if they are the same tho. I think their payload is less and the spring pack itself may be different. I'll check
Thanks! Nice to talk to you too
Cheers, Bebe
Old 01-16-2009, 12:52 PM
Here is something you might look into...
http://coloradofans.com/forums/viewt...t=leaf+springs
Old 01-16-2009, 05:19 PM
Desert Dan's Avatar
How about adding a new main leaf and using the existing main spring as the second leaf? you could also add a couple more leaves as well.
Or maybe by a set or Ranchos and then add a few more add- a leafs?
Ive seen some Colorado trucks in my area with big spring packs for load capacity.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 01-17-2009, 01:06 AM
This may be the same dude on flea bay...
http://cgi.ebay.com/ebaymotors/Super...Q5fAccessories
Old 01-19-2009, 06:09 PM
Nah, been there done that, have a set of hellwig overloads for about 2 years now.
Doing a spring over so I need a new main leaf. Mines warped
Old 01-19-2009, 06:11 PM
Dan,
That's why I was asking, trying to see if anyone has a throw-away spring pack, all I need is the main. I have a set of Tahoe HD springs I was going to use with a new main leaf to build a hybrid pack.
