01-17-2009, 10:38 PM
55 Watt HID kits
I have done a search and have not found anyone posts about the 55 watt bi-HID conversion kits installed in their trucks. I see alot about the 35 watt versions but nothing specific to the 55 watt models. If anyone has done it, or if anyone has knowledge of the headlight circuit maybe you can help me with a question.
Regular stock headlights in our H2 are said to use 8 to 15 amps when in use. The 55 watt conversion HID kits with the digital ballasts are said to use about 6 amps however they can use up to 20 amps for initial startup. My question is will the stock wiring and headlight switch handle this initial power demand or is it necessary to use the additional relay kits? Manufacturer says it's ok without the relay and it is plug and play, however want to check with others first before I listen to them and fry the wiring or switch.
01-17-2009, 11:38 PM
Re: 55 Watt HID kits
I have them on but too them off because with the 35watt the BiXenon works but with the 55watt there isnt enough power to power both... My passenger side keeps dying on me ... So I took them off until the manufacturer helps me out...
You wont fry any wiring or switches but You definitly have issues of it working right especially with our automatic headlights on feature ... The 55watt kit should have its own harness; the ballast will plug into the harness and then into the ballast ... The wiring harness gets its input from your factory plug to turn on. The it kicks the ballast on... Most of the kits I've bought comes with a direct power from the battery, but for some reason my 55watts arent getting enough power... So I have another upgraded harness I can try with them and see if they will work ... I'll try it later on tonight when I get home...
But, either way... There is a upgraded wiring harness that my dealer can sell me to boost my wattage to the HID harness that would help...
01-18-2009, 03:09 AM
I bought mine from these guys, it was pretty much plug and play. Haven't had any problems...55w bi-xenon... Has the ballasts and relay/harness...
http://www.retro-solutions.com/HondaTechGB.html - $160 otd...
'03 H2
01-18-2009, 04:30 AM
These are the exact ones I am looking at. So no problems so far? How do you like the lights? Alot of difference?
01-18-2009, 05:04 AM
Originally Posted by dochummer
I'm the one the posted that website... I've bought 3 kits from them. But it seems this one is giving me issues... Maybe its my ground ... Hey dochummer can you post pics of how you installed yours ??? Like where did you put the balast and where you tapped the ground cable ???
01-18-2009, 01:47 PM
I'll take a pic of my set up this morning after I wake up!
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
01-18-2009, 06:33 PM
Here's the pics
2008 GT2 Porsche
2009 DBS
01-19-2009, 12:12 AM
Originally Posted by porschett
Here's the pics
thanx for the pics bro ... I always wondered with the hood close would we have enough room there...
but where did you tie in the ground cable ??? Did you ground them at the horns ????
01-19-2009, 07:27 AM
Here you go. I grounded mine to the horn mounts on both driver and passenger sides  . Hey, it works. I checked with a meter and they work fine.  The Ballasts were mounted with some shorter screws that I had on my bench, and fit perfectly next to the headlamps. The relay was just zip-tied to the wires coming through next to the horn. I then tapped the power from the post under the fuse box cover. I left the original plugs close to the headlamps so I can swap back easily if I need to.
Overall, a lot brighter than the silverstars I had. The light isn't as "smooth" as with my wife's vehicle (stock HID's). It seems there are some darker spots than others. Most likely just the reflector not spreading it as well... She was driving it tonight and noted that 2 or 3 people flashed their brights at her so I've gotta re-aim them also...
'03 H2
01-19-2009, 03:23 PM
I came off the lights with a 10 gauge wire and ran it to the alternator mounting bracket. No better ground than that !!
2008 GT2 Porsche
2009 DBS
01-19-2009, 03:37 PM
I've been mounting them in the horn location...
I guess I have to wait for retor-solutions first and if they replace my wiring harness or kit ... I'll modify the replacement harness that way and ground it to the alternator and power it by tapping the power in the fuse box...
01-19-2009, 06:59 PM
So I guess in reality the retro-solutions kit is not just plug in. Do they come with the necessary relay kits or are the relays extra?
01-20-2009, 06:21 PM
In my case, it came with everything. The only thing I added were the 4 shorter screws to mount the ballasts. Everything else came with the kit and just plugged in or zipped on.
'03 H2
12-26-2009, 07:25 PM
BUMP-=
Is everyone still happy with this kit?
Did you get the problem fixed Rip-Speed?
I'm used to HID lights.... coming from OEM HID to the HUMMER was a big difference.
I'd like to get a set of HIDs and then use the DTR lights as fog lights if it's not too much of a pain.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
12-26-2009, 08:56 PM
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
Two years now and NO problems!
I've been stopped by other H2 owners, asking me where I got em'. Everyone that I know seems to be happy. Like I said before, It's the best mod I made to the truck. No more outdriving the headlights!
2008 GT2 Porsche
2009 DBS
12-26-2009, 09:36 PM
Porscette I forget do you have the 55 WATT?? If so do you get flashed?
4300 ??
What about you p......what color temp and watts?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
12-26-2009, 10:21 PM
For all that have these installled, do you, or have you run acroos any problems with the "auto" feature of the headlights. For example, when you first install the key and start the truck. Does this pose any problems with the interruption of power? I had them, but one would kick itself off at times during startup, but would work normally afterwards. Thanks
12-26-2009, 11:38 PM
Never flashed and no startup problems. When they first come on, it's like they're powering up, but it's only for about 2 seconds.
2008 GT2 Porsche
2009 DBS
12-26-2009, 11:59 PM
LOL I see by the title this is a "55 watt" thread so I'm guessing you have the 55 watter.
I saw a picture and they look good when on... not a lot of glare, but it was dusk, not dark, and cams probably play a role in distortion of pictures on the forum.
06-- I read of the OP of the link to the kit having that problem, and that the supplier gave him a harness with a capacitor in it... solved the problem.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
