Old 01-29-2009, 08:24 AM
DoubleAction's Avatar
DoubleAction DoubleAction is offline
DoubleAction is on a distinguished road
Default PIAA & OEM switch
Hi All,
Can somone offer me a wiring diagram for the (OEM extra fog lamp switch) located under the headunit so i can replace the PIAA swith.
Or just tell me where to connect the PIAA wires to (OEM extra fog lamp switch) located under the headunit .
I searched the forum but no clue
Please Help Me With This Issue
- HUMMER H3 Lux/Pkg (Boulder Gray) 2006
- Audi Q7 (White) 2009
Old 01-29-2009, 03:17 PM
Default Re: PIAA & OEM switch
Here is a link showing a way to connect a inexpensive 4 pin relay which enables a low amp 12v to grd circuit to activate a high amp circuit...
http://www.classictruckshop.com/club...h/foglites.htm
You can get one of these relays for under $5.00 however the install requires some experience with wire connectors and soldering to avoid problems with shorts. Care should be used in picking a open location to mount the relay in a accessible and clear area under the hood. Not under the dash.
The illustration shows the bosch 5th pin 87a which is not needed for this application...
Old 01-30-2009, 12:20 AM
Major Tom's Avatar
Major Tom Major Tom is offline
Major Tom is on a distinguished road
there are three wires off of the OEM switch.
A B C A=ground
B=accesories
C=12 volt +
I hooked up four Eagle Eye lights and used two OEM switches
Old 01-30-2009, 08:38 AM
A B C A=ground
B=accesories
C=12 volt +
Thanks Pal,
But how can i know wich is A B C on the OEM?
Are They writen on the OEM switch
Old 01-31-2009, 12:33 AM
Major Tom's Avatar
The pigtail wire harness that hooks to the OEM switch is marked A-B-C . The switch comes in two pieces. The switch & the pigtail wire harness. The switches were $27 each at the dealership. The pigtail was $35 each at the dealer. I found the pigtail on line for $16 each. Just Google GM part # 12101864
Old 02-04-2009, 11:18 PM
Thank you so much
