Old 02-01-2009, 09:16 PM
Yetti Yetti is offline
Default I think I broke it :(
seriously I set a light for the traction control and abs lights. couldn't clear them with my code reader. what is the deal?
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 02-02-2009, 01:18 AM
Default Re: I think I broke it :(
Could be something wrong but could be a glitch. Unhook the battery for a few minutes and see if it resets.
The other thing is and someone may correct me if I'm wrong but if the abs light came on, you may need to drive the truck to let the ecm recalibrate itself as far as the brakes/traction control are concerned.
Good luck, let us know what happens.
Mark
Old 02-02-2009, 02:07 AM
splne1's Avatar
splne1 splne1 is offline
This is a repetitive thread. check your wheel speed sensors on your hubs
Old 02-03-2009, 09:51 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Most code readers will not clear chassis or body codes, just powertrain codes. Should have it scanned with a scanner that can read abs codes and go from there
Old 02-04-2009, 01:06 AM
well it went off on its own, I figure it was based on key cycles. anyways I had been hot dogging it in the back yard in about 12" of snow and when I got on the hill to come back to the driveway it was spinning pretty good. anyways I hit the brakes to stop and it went nuts. set the lights and quit working. I backed up and hit the hill again and went up.
Yetti
www.wegotmud.com
www.glfwda.org
Old 02-04-2009, 01:09 AM
heres my backyard so you don't think I'm nuts.
Yetti
www.wegotmud.com
www.glfwda.org
