Old 02-08-2009, 09:18 AM
AK47's Avatar
AK47 AK47 is offline
AK47 is on a distinguished road
Default screach when running
i have a screaching noise coming from the from the front of the engine area i guess this could be the water pump ,,the serpintine belt looks ok ,,could it also be the belt adjuster pulley ?
Grant Ryeback
www.euroco-corp.com
http://www.hummertruckworld.com/EUROCO/
00423663114587
Old 02-08-2009, 06:14 PM
dochummer's Avatar
Default Re: screach when running
did you try pouring water on the belt with the engine running to see if the screeching stops? I had a screeching noise that we thought was a pulley, the belt looked fine, but it ended up being the belt...
'03 H2
Old 02-08-2009, 07:11 PM
o2man98 o2man98 is offline
o2man98 is on a distinguished road
Most likely the belt idler tensioner. Very common in these engines throughout the GM lineup.
2007 H2 SUV All-Terrain Blue - His
2008 H3 Alpha Graphite Metallic - Hers
Old 02-08-2009, 07:48 PM
AK47's Avatar
ok guys cheers ...i have orders up a pulley tensioner and idler pulley i will change the belt as well,,,i did hear it could be the W/AC Compressor ,,jesus i hope its not that it does not sound from there ,,,,thank you guys
Grant Ryeback
www.euroco-corp.com
00423663114587
