Old 02-09-2009, 02:50 AM
pablla4 pablla4 is offline
pablla4 is off the scale
Default how to lock the back door?
my power locking not working so i manually have to lock all the doors but i dont know how lock the back door. so when i drive and make a quick turn the car beeps and on the digital it says a door is open for a second than go off. the unlock/lock buttoin dont work in the car either. anyone have any idea? thanks
Old 02-09-2009, 03:49 AM
tomp's Avatar
tomp tomp is offline
Default Re: how to lock the back door?
Check fuse or relay?
Old 02-09-2009, 02:40 PM
use the key !!!
when you lock the drivers door with the key it locks all the doors...so they say...!
Old 02-10-2009, 02:22 AM
use the key !!!
i tried that but only locks the front door... i checked the fuses n everything fine
Old 02-23-2009, 03:24 PM
pdsq99f4 pdsq99f4 is offline
Sounds like you need a new door ajar switch on the rear swing gate. Take it out and check the connector for corrosion. Is your driver's door switch working propperly? Does the driver's window go up and down?
