Old 02-12-2009, 04:09 AM
hotstang46` hotstang46` is offline
hotstang46` is on a distinguished road
Default HID Expert Needed for Opinion/ trouble shoot help
So I am in the process of installing HID fogs on my H2 (i've actually been photographing process for a "How To" for ths site). I have encountered a problem that I think may be the bulb. I have a "working side" (driver) and "non working side" (passenger). I have enough mechanical knowledge to know the connections are all correct. The non working (passeger) side will flicker once and shut off immediately when I try to fire it up. I then switched the ballasts from one side to another and the same thing still happened. The passenger side still did not work and the drivers side did. So both ballasts work on the driver and both don't on the passenger. Question is, could the flicker and shutting off be from a bad bulb? My natural instinct tells it's a connection problem but I checked and rechecked and couldn't find anything.
Thanks for anyone's help
