02-14-2009, 07:15 AM
I have a brake question
I have a 05 h2 and I was wondering why I have rear drum brakes???? Every H2 I have seend has rear rotors?? It is a slate blue with Lux PKG and I was wondering if there is a conversion or if I should just leave it alone lol
02-14-2009, 03:03 PM
Re: I have a brake question
Post pics please.
There is a emergency brake drum as part of the rear brake system?
02-15-2009, 09:25 PM
Doesn't seem right... rear disk brakes here.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
02-17-2009, 12:04 AM
Sir, were you under the influence of alcohol when you looked at this?
02-19-2009, 02:21 AM
My truck has drums in the rear for the e brake There are disk brakes back there as well.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
02-19-2009, 04:00 AM
You did not say if you bouhgt it new or used.
Someone could have damaged the rear axle
and it was replaced with one with drum brakes.
I would do a CarFax and see what it turns up.
Richard
