Old 02-16-2009, 01:43 AM
peppers&eggs's Avatar
peppers&eggs peppers&eggs is offline
peppers&eggs is on a distinguished road
Default oil pressure problem
I have a 2004 and my oil pressure has been all over the place. One day the pressure is pinged passed 80 and the next day it is fine. When it is passed 80and I shut the truck off, the needle does not go doen to 0. It rarley makes it passed half way when the truck is off. This could be like this for 2 days and then all of sudden work fine. My question is if anyone has had this problem or can anyone tell me if this sounds like the pressure switch or the cluster acting up. Thanks in advance
Old 02-16-2009, 02:24 AM
Guinnessboy Guinnessboy is offline
Guinnessboy is on a distinguished road
Default Re: oil pressure problem
i would imagine it is the oil pressure relay.......my Z did the same thing to me, swapped it out and everything is fine.....kind of scary driving it when the meter says 0 for oil pressure isnt it!!!
Old 02-16-2009, 09:59 PM
pdsq99f4 pdsq99f4 is offline
Good luck finding your oil pressure relay! You most likely need a new IPC. They're pretty expensive, but you can replace the stepper motors in them. Usually the speedometer goes out.
