Old 02-23-2009, 04:30 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Default Throttle body bypass kit
Has anyone installed this...or have any info. Does it work? Is it just another con??
Old 02-23-2009, 05:06 AM
tomp's Avatar
tomp tomp is offline
Default Re: Throttle body bypass kit
It works, but you can do it yourself using parts from auto parts store. Not worth what they are charging for the kit
Old 02-23-2009, 06:17 AM
Tex_h2's Avatar
Cool,
So what do I need....and how do I install it??
Old 02-23-2009, 11:32 AM
My superchargered rig has had it done for several years. Tomp is correct do not pay for kit. It is basicly just 2 clamps, 2 nimples to screw into the holes and then a length of rubber hose long enough to make bypass. I did this to my 1999 Silverado.
The purpose is to reduce the temp. of throttle body cooling fuel which is less likely to ping etc.
Please this is a rough description of needed parts to do the bypass so double check. Just do not pay for the hyped up kit.
TAZ
