Old 03-13-2009, 10:39 PM
jmsspratlin's Avatar
Default Tranny Flush
Is the Dextron III the only recommended trans fluid to replace the stock fluid? I have reached 33K and need to flush the old fluid.. Thanks in advance....Jamie
Old 03-14-2009, 01:37 AM
IRA51's Avatar
IRA51 IRA51 is offline
Default Re: Tranny Flush
You could use syn ,mobil 1,or Redline,or Amsoil.
A government big enough to
you have.
-- Thomas Jefferson
Old 03-14-2009, 02:32 AM
Thought there was an issue that only Dex III was suitable?
Old 03-14-2009, 02:35 AM
HummerMann's Avatar
I think they recommend changing the fluid at 50K in the H2 owners manual, but it's cheap insurance to change it earlier and I've done some serious towing! I had my '06 done at 38k at an AAMCO dealer in one hour for 220. They told me the flush is a dealer tip off and doesn't do anything - to just change the fluid.
Hummer, like nothing else
Old 03-14-2009, 02:39 AM
Isnt there a difference in dropping the pan and flushing while changing the filter? arent you suppose to do all three things? i used royal purple in my truck and if you really want insurance you need to do the "tranny cooler bypass" search it
Old 03-14-2009, 03:07 AM
tomp's Avatar
tomp tomp is offline
GM discontinued the use of the Dex-III branding and recommends Dex-VI (6) as a replacement. The only full synthetic that meets this requirement is Redline and GM fluid. However, it was quite a while ago when I researched the companies and their Dex-VI specs so others may be on board now and have it too.
Old 03-14-2009, 06:03 PM
H2R's Avatar
H2R H2R is offline
H2R is on a distinguished road
It is my belief that Maintenance Schedule provided by GM is just that a recommendation under normal use. I have been wheeling in deep sand and have brought my Transmission temperature to above 200 degrees. My experience tells me the trans fluid breaks down above 170 degrees so I would change it. The only reason It went up is because I didnt air down like I should have. I have always used the dealer just because I want GM coverage.
2013 Sierra Denali
2012 Yukon Denali
1974 Corvette conv. (454ci)
31ft Gulf Craft Boat
Old 03-14-2009, 07:31 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Valvoline is marketing a full syenthetic DEXVI that has the GM approved license markings on the container as well.
