Old 03-22-2009, 03:12 AM
FUTP's Avatar
FUTP FUTP is offline
FUTP is on a distinguished road
Default Hid Install
Sorry if this has been asked before but i cant find it, Does and body know where i plug the Black and Red wire into the factor wiring harness? the factory harness has 3 plugs im not shure witch ones to plug them into....They should be "plug and play" to run off the factory oem harness right?
Old 03-22-2009, 03:55 AM
[__--MUD--__]'s Avatar
Default Re: Hid Install
HID lights are supposed to be wired direct to the posetive post on the fuse block (have to take the angled hood stop bracket off to pull the plastic housing completely off the fuse box.) and you can just get a self taping screw anywhere in the engine bay for the black.
Thats assuming you have one of the better hid kits where it only uses the factory light plugs as a signal trigger and new power runs to the lights so you dont melt all your wires in the engine bay...
