Old 04-06-2009, 02:05 AM
MAXFL MAXFL is offline
MAXFL is on a distinguished road
Default Air bags leaking down after lift.
PROBLEM SOLVED. It was the fittings at the compressor in a spot I could not see without being on a lift.
It is an even leakdown on both sides leading me to believe it is not the bags themselves but a compressor leak issue. I have done a basic inspection of the air system and checked for leaks with soapy water, but I have not put it back up on the lift and gone over every inch of line yet. I would think with the volume of air leaking it should be easy to find but I am missing it somewhere. Has anyone had a similar problem immediately follwing a lift? There were no issues with leaking prior to the lift.
Any help or ideas are welcome.
