Old 04-11-2009, 08:56 AM
c5mtl c5mtl is offline
c5mtl is on a distinguished road
Default another air suspension problem
Need some help...i have a service air suspension light on and the truck does sag after a day but the biggest problem is the compressor will turn on and run for 3 or 4 seconds and then turn off and i'm not able to start it again....can't use the inflator or the raise suspension button...nothing works till i shut the truck down and restart it...then the compressor start again and again runs for 3 or 4 second and dies
THANKS
It an 2006 h2
Old 04-11-2009, 12:59 PM
HummerMann's Avatar
Default Re: another air suspension problem
It could be lots of things! It sounds like you probably have a leaking air bag to start with if it's running that long, but it also sounds like your leveling sensor or sensors are bad. This is something that is best handled by a Hummer dealer. They have lots of experience with the air suspension and its problems.
Hummer, like nothing else
Old 04-11-2009, 05:19 PM
thanks....maybe i was not clear...the compressor wont run...it runs for a couple of seconds at start up and will totally shut down and wont run anymore...i cant even turn on the inflator
Old 04-11-2009, 05:33 PM
HummerJim's Avatar
There's a previous thread here somewhere about the fact that if it doesn't sense an improvement in the level with the sensors, it shuts off and locks out the compressor so it won't run and run. HumTech could tell you more about it.
Old 04-11-2009, 08:46 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
What happens is the system does not detect that the rear suspension is changing height, not raising, at that time it will set a code and disable the suspension system. With a key cycle the code goes into history and that is why the compressor will run again but as soon as the code sets current system is again disabled
1998 Chev Z71
2007 Chev Trailblazer SS
