Old 12-23-2002, 06:41 AM
Steve R Steve R is offline
Steve R is off the scale
The question has come up as to the differences between gasoline and diesel. In the future the possibility of a diesel or turbo-diesel option for the H2 is likely.
In a nutshell:
Upside: About 45%-65% better gas mileage (fuel economy), longer lasting engine, more reliable, greater torque and power at lower rpm's, increased towing capacity, and some like the raw sound it makes.
Downside: Engine cost more, adds $3,500 - $6,000 (higher if turbo-charged), tends to be slow & sluggish to throttle input, often has a distinct diesel odor and substantially more engine noise. Fuel can be more difficult to find.
It used to be argued that diesel was worse for the environment, especially on account of what can often be visually seen as 'black smoke' coming from the exhaust. In fact, research supports that diesel is actually less impacting on our environment...this arguement continues today; making it a 'toss-up' in terms of which is better or worse.
From experience I can attest that a diesel engine can last well over 500,000 miles (and more!!!) In our H2's we could expect to get about 15-16 mpg in the city. A diesel engine has no distributor or ignition system as such; it requires only fuel, air and combustion in order to operate....this simplicity adds to reliability offroad (and in battle). A diesels higher compression engine develops substantially more horsepower and torque at lower rpm's, making it a great choice for towing or hauling heavy loads. Many H1er's strongly prefer the power-range of the diesel over gas models.
The diesel doesn't have the smooth acceleration or cruising movement that we're all used to...it's much more like a tank. To account for this, the turbo-charger is often added to give the diesel engine a bit more "UMMPPH" when you put your foot down. The turbo provides the fuel/air mixture to be "jammed" under pressure into the engine, this "boost" gives more gas-like performance.
I know I'm forgetting a few things, but that's a good start and a working foundation for understanding the key differences between each fuel. Most people remember back to when diesel was cheaper per gallon, today it's about the same. Either way, the environmentalis hate us.
Please feel free to ask any questions. [img]/infopop/emoticons/icon_wink.gif[/img]
