Old 04-29-2009, 01:50 AM
H2inMD H2inMD is offline
H2inMD is off the scale
Default Squeal and flapping sound
2003 H2 95000 miles. put new drive belt and tensioner on. Still need to do the A/C belt and tensioner.
It seems to squeal like a pig as I start out. It might clear up and it might not. Sometimes if I accelerate it start again.
Seems like it neutral it hardly makes a squeal.
Then, if you step on the gas, sometimes it will make a flapping sound, weird. I can't really describe the sound its different. The check engine light will flash. no codes though.
Ideas?
thanks
Old 04-29-2009, 02:19 AM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
Default Re: Squeal and flapping sound
Had something similar on my 2006 w/ 64k. Dealership replaced both tentioners, fan clutch, and both belts. Solved my issues. I didn't realize there were 2 tentioners, etc until they pointed that out.
Old 04-30-2009, 10:37 PM
Default Re: Squeal and chattering/misfire type sound
Its seems to get worse if you push the engine, we were reving it up to try to hear the noise and it got worse.
next step , when its cold, I am going to take the belt off and see if it still makes the squeal. This will start to isolate the problem.
any other ideas?
Old 04-30-2009, 11:42 PM
H2 Bill H2 Bill is offline
On the "main drive belt" there is a tensioner pulley and an idler pulley. I had to change both to make the noise go away.
1994 Chev Suburban Blown
Old 04-30-2009, 11:46 PM
we've diagnosed it better, so I started a new post. Whistle from Intake manifold?
Old 06-15-2009, 10:54 PM
Default SOLVED Re: Squeal and flapping sound
Unbelievable. 3 nuts/bolts broke off on the exhaust manifold passenger side.
You got your tick tick sound, then as you accelerate, it whistles(cat screech) with more exhaust flow, then if you get on it, the manifold itself is lifting on and off the head hence the flapping/banging sound.
Saw the tech bulletin on the fasteners, why didn't the original dealer ever contact me, why not GM. The tech bulletin says to replace if brought in for manifold service. Guess if it fails you bring it in. Would have been nice to change them before the failure.
Old 06-16-2009, 06:49 AM
pdsq99f4 pdsq99f4 is offline
Default Re: SOLVED Re: Squeal and flapping sound
If you were GM would you send letters to everyone who owns a Hummer saying "you may have some exhaust manifold bolts break, so watch out"? Do you know how much that would cost? It would definitely bring me more business though as a technician. I'm sure if you got your vehicle serviced by someone who KNOWS your H2 they would have seen the broken bolts a long time ago. I know I would have.
Old 06-16-2009, 05:41 PM
Well maybe thats why GM is now Gobvarmit Motors and Hummer is now a Chineese Entree' best served with 93 octane
Dont get my wrong I love my H2, but maybe they should tell you things, i dont know. Actually, i have never kept a truck or car past the warranty before, so @ 95K this is new territory for me.
As for service,what service. I get the oil and fluids changed. i did the spark plugs. What else do you really need serviced? And its not at the dealer$$$$.
" they would have seen the broken bolts a long time ago. I know I would have."
Really, you need to know the bolts are susceptable to breaking BEFORE it happens, Also, how would you have seen the broken bolts since the flimsy heat sheild covers them, until the heat shield rusts away?, but thats another problem.
For the future, I think an Alldata subscription is in order for every car/truck i own, just to keep current.
still love my H2
2003 Green
all stock
with broken manifold bolts and a rear license plate tray, the black thing, where factory tape and a plastic clip dont cut it, but thats another repair.
Old 06-17-2009, 12:50 AM
IRA51's Avatar
IRA51 IRA51 is offline
exaust manifold bolts break on all vehicles ,it's no big deal to change them . make sure you don't over tighten the new ones ,the heads are aluminum and you don't want to strip them . FYI my H2 has not done that yet in 85000 miles . this could be your excuse to install headers .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-18-2009, 03:15 AM
Faustus100 Faustus100 is offline
Faustus100 is on a distinguished road
I wonder if thats the same quick ticking sound I get on the drivers side when I press the gas?
Old 06-18-2009, 07:28 PM
IRA51's Avatar
I'm sure it is ,and it is only going to get worse untill you fix it .
you have.
-- Thomas Jefferson
Old 06-19-2009, 02:32 AM
Thanks Ira Ive been worried about it for a while now
Does anyone have an estimate on the cost or is it something that is pretty easy to do yourself?
Old 06-19-2009, 06:08 PM
IRA51's Avatar
realy not that hard take off all remaining bolts ,pull the manifold away from the head take a vice grips and remove the broken bolt . if it is flush with the head than you will need to remove the manifold and use an easyout and remove the broken bolt . if it has a gasket replace it . use new grade 8 bolts to reinstall the manifold and that should fix it . do not over tighten the bolts about 35 to 40 lbs is all that is needed on manifold bolts .
you have.
-- Thomas Jefferson
