Old 04-29-2009, 02:42 PM
Default Water Leak - Sunroof
I have a leak, supposedly from the sunroof, which rolls down the A pillar and soaks the drivers side front and rear floors.
Anyone ahd this issue and have any advice?
Also, when i'm at highway speeds, I can see the sunroof movin up and down, si I'm sure the mechanism is loose and therefore not sealing properly and thus the leak.
Anyone had this issue? Is there an easy fix? Cost?
Thanks!
-Matt
06 - Black Caddy SRX
Old 04-29-2009, 04:19 PM
tomp's Avatar
tomp tomp is offline
Default Re: Water Leak - Sunroof
It might not be the sunroof and could be marker lamps on roof or combo of both leaking. Sunroofs are a bad idea for this very reason
Old 04-29-2009, 11:53 PM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
Also make sure the sunroof drain plugs aren't stopped up. You can spray compressed air to try to clear them. The sunroof will move up and down at highway speeds. That's not going to cause a leak, just some wind noise, unless your rubber gasket is broken and water accumulates. Again check those seals around the marker lights (like Tomp said) and check your drain plugs. Good luck.
