Old 05-02-2009, 01:41 PM
daemi daemi is offline
daemi is off the scale
Default Technical Question.
Hi All
I have a problem with my 2006 H3, today apparently the Engine warn light went on.
So I went with Car to my Garage and there they read out the Fault memory and the mechanic said that piston #2 has some misfire.
The Mechanic was unfortunately not A Hummer mechanic therefore he was not so sure what to say he only mentioned the ignition coil might be the problem.
Now the Engine Warn light went off!
Did anyone had a similar problem with aH3 and if what was the reason and of course the solution?
Thanks for the Help
Damiano
Happy owner of a 2006 H3 located in Switzerland
