Old 05-05-2009, 03:38 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Default Weird Noise, can you help?
Ok, there is this weird noise coming from the drivers side front tire when I'm turning. Now its only sometimes and when I first startup. Time of the day doesn't matter and after driving for a few minutes it stops. Sometimes I notice it more when turning to the left. Checked underneath and don't really notice anything loose, broken or leaking. Can anyone shed some lights on this??
Old 05-05-2009, 03:17 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Default Re: Weird Noise, can you help?
2:38 am?
What does it sound like??
Hub Bearings?
Diff?
ball joints?
Old 06-03-2009, 03:47 AM
ISAS ISAS is offline
ISAS is on a distinguished road
Did you ever find problem ... I have the same thing it is a squeaking noise it is embarrasing
Old 06-03-2009, 04:01 PM
mikejr's Avatar
mikejr mikejr is offline
does it sound like a metal on metal creak or cracking?
2009 H2 Silver Ice LE
Old 06-03-2009, 04:57 PM
jack front end up and ck for up/down movement in wheels.
most likely hub(s).
Old 06-03-2009, 08:38 PM
IRA51's Avatar
IRA51 IRA51 is offline
the bearings in the hubs are known to go out , also check that the boots on the front CV's aren't ripped ,if so you may need a new or rebuilt drive axle . new is better .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-05-2009, 07:58 PM
sweetmamah2's Avatar
sweetmamah2 sweetmamah2 is offline
sweetmamah2 is on a distinguished road
I just replaced my left bearing and it made the exact sound you have descrived.
Old 06-06-2009, 11:14 PM
Tex_h2's Avatar
How much to get this fixed??
Old 06-07-2009, 07:05 PM
AUHUMMER's Avatar
AUHUMMER AUHUMMER is offline
AUHUMMER is off the scale
I was quoted $500 and $550 here, but I bought the hub assembly @ Advance for $185 and did it myself. 2.5 hours of wrenching to save about $350.
Old 06-13-2009, 01:45 AM
Tex_h2's Avatar
Yep, it was the hub....not too bad...350.00 non dealer...
