Old 05-18-2009, 12:07 AM
solarflare's Avatar
solarflare solarflare is offline
solarflare is on a distinguished road
Exclamation H2 Bang on Cold Startup?
I've noticed now a couple of times, when I go out to start the H2, it makes a bang sound from the engine compartment.....only does this on the first cold start up. It's not a rattle or a tap...
It's when you turn the key, almost as though I'm not holding it long enough...???? Or, like the engine didn't shut off right....and gets back in sync when started.
Very hard to describe....but I remember my 05' did it a couple of times......anyone know what it is?
2007 Hummer H2
2010 Jeep Rubicon
Old 05-19-2009, 03:17 AM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
Default Re: H2 Bang on Cold Startup?
I had that happen as well. The truck seemed like it would almost lunge with a noise from the engine/drivetrain. Never checked it out, but since I changed the T-Case fluid (Royal Purple) it hasn't happened since (T-Case fluid was 65k old). Not sure if it's just coincidence or not. Been a few months.
Old 04-13-2011, 01:49 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
OLD POST
Anybody know what could cause this?
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 04-22-2011, 03:10 AM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
No idea, but I get it, too. Anyone?
