Old 05-29-2009, 08:40 PM
rkhal rkhal is offline
rkhal is on a distinguished road
Default 2004 H2 overheats.
I have a 2004 H2 and I am getting overheating indications on the driver corntrol center and the heat gauge. It was fine when I drove it home and the next morning at 2am when I started for work it overheated with 5 miles of home. I have changed the thermostat, the water pump, the fan clutch and the coolant cap and it still overheats. I am desparate. Any ideas?
Old 05-29-2009, 10:23 PM
tomp's Avatar
tomp tomp is offline
Default Re: 2004 H2 overheats.
Might check color of fluid to ensure it's not getting mixed with tranny fluid!
Old 05-29-2009, 10:42 PM
porschett's Avatar
Blown head gasket?
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 05-30-2009, 12:22 AM
IRA51's Avatar
IRA51 IRA51 is offline
Is it useing coolant ? if it is you need to find the leak . if not it may be a cloged radiator and you may need to have it rodded out or replaced . as said B4 if you mix Dexcool with the green antifreez it will clog the system. if it's a bad head gasket it wiil show up at the tail pipe as a mist or worse. you can also pull the spark plugs and see if they look right ,if one is a differant color you can bet that you have a leak in that chamber and it is ether a cracked head or bad head gasket . head gaskets go bad on these engins because people never change the coolant and beleive GM that Dexcool is good for 100000 miles ,in fact you need to flush and change it with a thermostat every 50000 miles or 3 years which ever comes first .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-30-2009, 12:59 AM
No coolant usage --- 60,000 miles. No none gm antifreeze -- confusing thing is it didn't gradually start getting hot --- just all of a sudden --
don't think head gasket as no water in oil or mist in tail pipe --- haven't pulled plugs yet
Old 05-30-2009, 01:28 AM
IRA51's Avatar
try undoing the radiator hose's from the radiator and get a garden hose and a rag use the rag as a seal and stick the hose in the bottom of the radiator and turn the water on full blast with the upper hose off the radiator ,you will need to hold it in. see if you get the water to come out the upper inlet of the radiator with the same force as the water going in. if not you have a cloged radiator .
you have.
-- Thomas Jefferson
Old 06-05-2009, 04:47 AM
pteam's Avatar
pteam pteam is offline
pteam is on a distinguished road
Do you have the fan shround on? You must have it on or it will periodically overheat, one of my h2s did from the previous owner taking the fan shroud off.
My cars:
Lamborghini Murcielago
Supercharged Viper 800 HP Special Edition #49 of 50
Porsche Boxster S
My Hummers:
08 H2, 22 in rims, 6 HID lights, 20 in TV with DVD
4 H2 limos 3 have lighted dance floors + ceilings, 1 has Zebra interior 24-26 passengers
H2 Limo 26 pass lighted dance floor (sold)
H2 Limo 24 pass (sold)
03 H2 (sold)
H1 Open top (sold)
FirstClassLimos.net - H2 limos and party buses in OH & PA
my car collection
Old 07-03-2009, 02:13 AM
Okay, you aren't going to believe this. I changed the thermostat, the radiator cap, the water pump, the fan clutch and the sensor and it still overheated. I refused to believe that it could be the radiator because it came on so suddenly. No gradually becoming less efficient at cooling, just wham. I didn't believe it could be the head gasket because I had no water in the oil or in the transmission and no steam coming out of the tail pipe. So before I got serious about the heads I pulled the radiator and had it rodded out. The main part of the radiator was fine but the nipple for the small hose going to the overflow tank was plugged. (it only has a small orfice deep within.) When that was unplugged the problem went away. I drove it for over 2 hours today in 100 degree plus temperatures with the ac on and a lot of idling. Temperature was rock solid.
Old 07-03-2009, 04:03 AM
Intercooled's Avatar
Intercooled is off the scale
Thanks for sharing..good find!! I'll Keep that info in the memory banks!
2006 H2 SUT Fusion Orange LE
