Old 06-02-2009, 03:44 AM
HumminNBoatin''s Avatar
Default H2 Winch Controller Plug Relocation Warn/Milemarker
Ok so I went to use my winch at the Kinzalow's run in TN to pull an H3 out of some trouble only to realize it did not work. Not a good time to find out your winch is not working. Anyway...
After some trouble shooting I found out that the controller plug on the bumper was corroded so bad one of the pins on the inside was rusted completely out. I am assuming it was due to road salt working it's way into the plug as sometimes the cover will fall off.
You can see from my pic on the original install in January how bad the road salt blasts the front of the truck. Well it only takes one day of salt blasting into the plug to cause it it rust out quickly.
So I took the H1 controller plug and applied it to the H2. Take a look.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 06-02-2009, 03:50 AM
Default Re: H2 Winch Controller Plug Relocation Warn/Milemarker
no pics showed
Old 06-02-2009, 04:51 PM
dochummer's Avatar
Nice work! Does that cap just pop off?
'03 H2
Old 06-02-2009, 09:40 PM
Its pretty much a rubber plug/cap. You just flip it off.
Old 06-03-2009, 10:37 PM
La.Swamp Lobster's Avatar
La.Swamp Lobster La.Swamp Lobster is offline
La.Swamp Lobster is off the scale
Nice job!
Old 06-04-2009, 01:13 AM
Try to squirt some petroleum jelly into the plug sockets.
Old 06-04-2009, 04:17 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
You stole my Idea... But I like it.
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 06-04-2009, 02:16 PM
I stole your idea?? Did you design the H1 Winch controller plug in??
I really turned out great. I was kinda worried about the wind on it a highway speeds but I think the hood helps to move the air over it just enough to not affect it at all.
