Old 06-06-2009, 09:38 PM
danaspigs danaspigs is offline
danaspigs is on a distinguished road
Default CONDENSATION IN TRUCK
JUST PURCHASED A 2006 HUMMER H3 AND AFTER A HEAVY RAIN, I GET EXTREME CONDENSATION ON THE INSIDE WINDOWS AND SUNROOF. WIFE JUST NOTICED A STREAM OF WATER COMING FROM UNDERNEATH THE GLOVE COMPARTMENT. LIVE IN SOUTH FLORIDA ALSO HAVE AN SWOOSHING NOISE FROM AC WHEN ACCELERATING PASSENGER SIDE
Old 06-07-2009, 12:39 AM
Default Re: CONDENSATION IN TRUCK
I'm assuming this H3 has a sunroof. I'll bet you have a plugged drain tube. Open your s/r and look at both front corners to see if there's a visible blockage(dirt,pine needles,etc) that can be easily cleared. If you don't see anything then it's probably dirt or some other debris stuck somewhere down the tubes. You'll need to use some compressed air and a nozzle to blast it out from that end.
Old 06-07-2009, 01:35 AM
what about the trickle of water underneathe the glove compartment. possibly an ac issue
Old 06-07-2009, 02:11 AM
Could be, but try the s/r drains first. Water has a funny way of ending up in odd places.
Old 06-08-2009, 05:48 AM
HBH3 HBH3 is offline
HBH3 is on a distinguished road
I had that happen on my previous H3. DRTYFN is right, it is the drains being clogged. Water will seep into the inside and spread all over. I bet if you remove the liner you will see it. Also lift the whole carpet and you will see water. This is why on my new H3 I did not get Sun roof
Old 06-08-2009, 08:03 PM
is this going to be an ongoing problem or were you able to get yours fixed dealer already check drains and repositioned them.
